avatar_Spark24
Кто может подсказать есть ли МК (мотор-колесо) с параметрами:
Автор Spark24, 28 Янв. 2011 в 15:01
Spark24
Уважаемые господа! Написал по рекомендованной ссылке
www.crystalyte.com
выкладываю ответ, может кому пригодится. (Сначало мое письмо)
crystalyte@yahoo.cn
Dear Kenny! You welcome of asking questions and I have some.
I`d like your Crystalyte Front HT2425  motor.
I want to ask you:
1. Can you say if it possible freely ride if you swich off electric power?
Or your motor begin to brake?
You see, I`d like idea: motor helps me with acceleration and climbing up hills and then I continue to bike using only man (or mainly) man power.
Is it realistic?
2. I`ve seen specs of your motors, but I was not able to find the weight of the motor.
3. And where I can see prices?
Получил ответ:
The front electric bike motor HT2425 available.
It is weight with 6kg/ea hub. Yes, the web site no motor's weight. We will update the information next. thanks
See the reply in detail down below **
** It is available ( possible ) freely ride if the motor switch off electric power.
** But it have little resistance which compare with the normal bicycle.
** The motor will not have brake.  It is the brushless motor no gear so it will turn freely.
Is it realistic?
** Yes, it is available.  You can use your man power to ride as the same time when you switch on the electric bike. We have the system for Pedal Assist System. It mean when you pedal the motor will work. when you do not pedal motor will not work. It will meet the europe bike law.
** We do have the system for motor start immediat like the motorcycle. It mean man not need to pedal. The motor will work with turn on the throttle. It is special for US market.
** 6kg/ea front motor. and 6.8kg for rear motor.
** See the price in attached. Usually I sell the motor kits to Wholesalers. Considering we do not have distributor in your country so I send you the distributors. The price will increase 15% when the order less than 100pcs quantity.
It is okay for you to order 1 kits , I will check the shipping cost when you tell me the detail of the materials you need.
While order the kits you have to tell  me the shipping address and phone no. So I will check the door to door service cost.
Greetings, Kenny.
Кенни так же выслал спецификацию по моторам и аккумуляторам (с ценами), формат pdf.
Спасибо всем за участие.        Киев. Олег.
Демократия, это когда два волка и одна овца обсуждают кого подать на завтрак
andreym
www.crystalyte.com
выложите пожалуйста пдф-ку - думаю тут многим интересны цены "от производителя"
Spark24
Выкладываю Crystalyte Motor kits Prices 20101202 и Lithium battery price list 1st Dec 2010
Только не знаю точно увидите ли вы их (я как-то выкладывал файлы, а сам их с сайта не видел...) Ссылка не работает - пишите, вышлю (Spark24@mail.ru)
Ампервел
Ну то есть судя по переводу МК со свободным ходом там. И аккумы интересные литий марганцевые.
andreym
Кристалай не выпускает моторов с планетаркой
только Direct-drive!
Spark24
А кто объяснит, отчего МК такой  тяжелый (6кг)?
И еще, там где-то прочел, что он бессенсорный и включается когда скорость движения 5-9км/ч. Интересно, а вести велосипед в горку, просто помогая включенным двигателем можно? Ведь скорость движения редко бывает более 5 км\ч, и, интересно, а закатывать велосипед по лестнице домой?
И еще, моторы бессенсорные, а в спецификации моторов, внизу в Remarks читаю:
"hall effect sensor" - это как?
И что такое e-brake cut-off? - это тормозные ручки?
andreym
новые моторы от кристалайта действительно безсенсорные
и контроллеры для них специальные
про 5кмч наверное написано про датчик педалей - типа пока крутишь, едет
вообще конечно моторы с hall-сенсорами на низких оборотах гораздо лучше себя ведут, синхронизация не срывается и все такое
e-brake это рекуперативное торможение должно быть = опять же непонятно как оно работает на без-сенсорных моторах...
Spark24
andreym
